How can I create a rotating monitoring point? |
September 10, 2006, 20:09 |
Dears,
I want to monitor the velocity magtitude near a blade in my pump flow simulation. For the blade is rotating with a speed, and I only can create a stationary monitoring point(surface->points), when the blade is rotating, the point is far and far away from the blade. So can I set the point rotating with a speed too? or I can do it in another way? Thanks a lot. Andy |
Monitoring Torque on rotating body in MRFSimpleFoam | mahendra | OpenFOAM Running, Solving & CFD | 41 | March 18, 2019 21:08 |
Meshing a Sphere | Ajay | FLUENT | 10 | September 3, 2016 14:18 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
[Gmsh] Gmsh and samplesurface | touf | OpenFOAM Meshing & Mesh Conversion | 2 | December 10, 2007 02:27 |
Monitoring data at a point within CFD domain. | James | Siemens | 1 | April 17, 2007 15:02 |
