September 22, 2006, 14:46 |
Fluent 64 bit on FC5 (AMD Opteron)
Dear All,
I get the following error while running Fluent 6.2.16 in a AMD 64 bit machine with FC5 64 bit OS: /usr/Fluent.Inc/bin/fluent: line 3600: unexpected EOF while looking for matching ``' /usr/Fluent.Inc/bin/fluent: line 3878: syntax error: unexpected end of file Is this has already been discussed in the forum? If not please advise. Thanks. saa_pondy. |
September 24, 2006, 22:01 |
Re: Fluent 64 bit on FC5 (AMD Opteron)
Downgrade bash to version 2.05
September 25, 2006, 04:28 |
Can it work with bash 3.0 ?
September 25, 2006, 08:43 |
I downgraded to bash 3.0, subsequently I get the following:
[root@nrml ~]# FLUENT_ARCH=lnamd64; export FLUENT_ARCH [root@nrml ~]# /root/Fluent.Inc/bin/fluent & [1] 12115 [root@nrml ~]# sort: invalid option -- 2 Try `sort --help' for more information. Error: program /root/Fluent.Inc/fluent6.2.16/cortex/lnamd64/ does not exist. The versions available in /root/Fluent.Inc/fluent6.2.16/lnamd64 are: 2d 2ddp_host 2d_host 3d 3ddp_host 3d_host 2ddp 2ddp_node 2d_node 3ddp 3ddp_node 3d_node Please advise. Thanks. |
September 25, 2006, 16:28 |
Did you success with bash 2.05?
September 26, 2006, 16:01 |
I get the same problems and I dont know what to do.
September 26, 2006, 22:01 |
Try bash 2.05.
September 27, 2006, 14:24 |
I tried and it didn't work. Which setup do you use for running your Fluent ?
Thank you. |
October 6, 2006, 12:44 |
You should download and install the Critical Patch 3 from site: http://www.fluentusers.com/fsdc/fsdc...f1=1&f2=0&f3=0
You will find out the patch after selecting the platform and click on Show Optional Packages. Yizhou |
AMD Opteron 2389 vs. Xeon W5580 | soni7007 | Hardware | 1 | May 3, 2009 18:42 |
Fluent gives libc error on 64 bit AMD Fedora 9 | Kumar | FLUENT | 3 | October 7, 2008 13:52 |
Fluent and AMD x2 | D_Lichu | FLUENT | 2 | September 21, 2008 18:38 |
FLUENT on Dual AMD AthlonMP system? | Arild | FLUENT | 2 | January 10, 2002 05:12 |
Running Fluent on Linux AMD machine | David Reinbold | FLUENT | 5 | September 21, 2001 18:08 |
