syntax error when interpreting UDF
Old   September 26, 2006, 08:14
Default syntax error when interpreting UDF
Erik
I have a problem when I interprete a UDF in Fluent. I think my C source code is correct, but when interpreting I get a syntax error in line 2.
My C source code is:
#include "udf.h" /* this line must be at the beginning of every UDF-file */
DEFINE_PROFILE(inlet_velocity,t,i)
float x[3]; /* this will hold the position vector */
float z; /* define z as a floating Data Type */
face_t f;
begin_f_loop(f, t) /* Loop over all faces in the thread passed in the DEFINE macro argument */
F_CENTROID(x,f,t);
z = x[3];
if (z <= 0.0143)
F_PROFILE(f, t, i) = 5.0 * (double power(z/0.0143, 1.0/7.0));
else
end_f_loop(f,t)
I hope somebody can help me with this problem.
Old   September 26, 2006, 20:51
Default Re: syntax error when interpreting UDF
Ahmed
Try writting the first line as #include <udf.h>
Old   September 27, 2006, 02:59
Erik
That doesn't seem to work. But thank you for your response
Old   September 27, 2006, 07:52
cadaei
I have modified it a little and it compiles.
real x[3]; /* this will hold the position vector */
real z; /* define z as a floating Data Type */
face_t f;
F_CENTROID(x,f,t);
z = x[2];
if (z <= 0.0143)
F_PROFILE(f, t, i) = 5.0 * (pow(z/0.0143, 1.0/7.0));
else
F_PROFILE(f, t, i) = 5.0;
end_f_loop(f,t)
Parse Error:- Interpreting UDF on remote terminal moataz.che FLUENT 1 March 7, 2017 14:13
parse error while interpreting udf Kristin Fluent UDF and Scheme Programming 3 March 15, 2012 06:43
UDF: DEFINE_CG_MOTION for vertical jump motion of an electrode! alban Fluent UDF and Scheme Programming 2 June 8, 2010 18:54
parse error with interpreting UDF ivanbuz Fluent UDF and Scheme Programming 2 August 13, 2009 18:29
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
