October 5, 2006, 20:52 |
Hypersonic flow capabilities
Can FLUENT handle hypersonic flows, i.e. say a velocity of Mach 20 - 30, which may be experienced by space shuttles during reentry? If not, is there any other software in the market which can, or is specifically suited to do so? Thank you. |
October 5, 2006, 21:03 |
Re: Hypersonic flow capabilities
If you write the proper UDF functions to handle the effects of dissociation on fluid properties, the answer is Yes
October 6, 2006, 09:10 |
Fluent's density based solver(Coupled sover) does not have any limitation on Mach number. Using UDF for air chemistry to account for dissociation of air, you can get better results.
June 4, 2014, 14:02 |
UDF to Model Finite Rate Chemistry
Mike
I am simulating hypersonic flow over a sphere. I would like to use Fluent's Finite Rate Chemistry Model. I have a reaction file which I used on CFD++ software. However, I realized that I need to re-format this UDF to use in Fluent. Does anyone have advice on the structure of this UDF? If anyone has an example UDF with the correct format for the reactions, I would be greatful! Thanks |
Hypersonic flow setup | screech1987 | STAR-CCM+ | 6 | April 27, 2011 15:00 |
Hypersonic flow rhoCentralFoam | ishaninair | OpenFOAM Running, Solving & CFD | 0 | April 7, 2011 04:38 |
Hypersonic flow | Subramani | FLUENT | 8 | May 7, 2007 20:02 |
Multigrid for hypersonic flow | Jeff | Main CFD Forum | 0 | October 20, 2002 20:50 |
Hypersonic flow applied to blunt nosed (ie. 2d bodies) | manishkumar | Main CFD Forum | 1 | January 10, 2000 22:36 |
