blade passage flow
Old   October 12, 2006, 10:55
Default blade passage flow
Babu
Hi all:
I have got an incompressible flow (M<0.2) model built for a sector blade passage with a clearance present between the blade and the outer casing. I got the complete test information (profile) right from inlet to the exit.
For this case I tried giving inlet total pressure and exit static pressure profiles to calculate the mass flow and I found it is 20% less. I'have checked with the density, which is constant.
Can someone suggest me to know what boundary conditions can I really fit and kind of turbulence model I can use to simulate one blade passage to match the test.
Regards Thanks in advance Babu
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 08:33
Re: how to do this turbine blade passage flow nanl manish Fidelity CFD 1 November 2, 2006 23:01
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 08:42
Re: how to do this turbine blade passage flow nanl manish Phoenics 1 February 21, 2006 09:59
Re: how to do this turbine blade passage flow nanl manish Siemens 0 January 12, 2006 11:37
