Filling air-filled microtube with Water using VOF
Old   November 6, 2006, 11:17
Default Filling air-filled microtube with Water using VOF
Ybes
Hello everyone,
i am trying to fill a small 2-D tube/chamber with inlet width of 1.5 mm, initially filled with air, with water. Inlet Velocity is 0.0005 m/sec.. Outlet is set as Pressure-Outlet. I am using the VOF-model and spalart-Allmaras or Low-Re-k-e-model, as Re<200. Wall-adhesion is enabled. To allow higher sub-time steps i coarsened the grid, so that a time-step of 1e-4 is (larger time-step is however risky) possible. This still takes a lot of computational time, but i can't find a better way to speed up the simulation. i set the operating pressure to 101325 and outlet pressure to 100, i am not sure if these pressure values are correct. Can anyone help me please?
Modelling free falling water into a air filled duct? sandmike_83 CFX 4 August 24, 2010 03:27
air bubble is disappear increasing time using vof xujjun CFX 9 June 9, 2009 07:59
VOF for water drop in air Talia FLUENT 0 September 3, 2006 05:57
Help!!!problems in air jet into water bath kim FLUENT 4 June 9, 2003 07:04
Air and Water VOF model, Error?? boris FLUENT 5 July 19, 2002 03:08
