October 31, 2006, 06:51 |
BC :pressur inlet
Hi all, how to set total pressur inlet and total temperature inlet in incompressible flow entring pipe i have static temperatur,static pressur and nember of Re.
thanks for all |
November 1, 2006, 04:19 |
Re: BC :pressur inlet
Hi for incompressible flow,we have; p0=p+.5dv^2(1) h0=h+v^2/2 or cpT0=cpT+v^2/2 thus: T0=T+v^2/(2cp)(2) where p0=total pressure,p=static pressure,d=density,v=velocity magnitude,T0=total temperature,T=static temperature,cp=constant pressure specific heat coefficient. since velocity and static temperature are known,using above equations you can find p0 and T0.Note that for incompressible flow cp=cv=c(approximately)and you can use equation(2)for both liquids and gases.Re=VD/v wher V=velocity magnitude,D=pipe diameter,v=cinematic viscousity coefficient Re,D and v are known thus:V=Rev/D. From: Salar Askari ,University of science and technology,Thern,Iran.
November 1, 2006, 11:36 |
thank's very well
Species mass flow inlet | lorenz | FLUENT | 3 | March 15, 2012 07:26 |
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure | jola | FLUENT | 1 | May 5, 2011 14:33 |
Inlet Velocity in CFX | aeroman | CFX | 12 | August 6, 2009 18:42 |
Inlet table in STAR-CD | Sachin | Siemens | 1 | March 26, 2008 10:22 |
what the result is negatif pressure at inlet | chong chee nan | FLUENT | 0 | December 29, 2001 05:13 |
