time step incompressible flow
I want compute an unsteady incompressible flow expluctly. I gave the courant number but you obtain this message :
"You cannot use global time stepping to compute unsteady incompressible flows" How to run? thanks |
Re: time step incompressible flow
In "unsteady formulation", you must choice "1st order implicit" or "2nd order implicit"
Hello
I have a similar problem. I'm doing a transient, compressible (UDF for density and speed of sound), FSI problem with the use of system coupling. I would like to simulate a pressure wave hitting an object, but i get the same error as the topic creator, even thou my fluid is compressible...help? Will implicit time formulation, for the explicit density-based solver simulate properly the above mentioned phenomena? thanks in advance for any help |
did anyone get rid of this error? I got the same one although I want to simulate an unsteady compressible case! |
I also got the same error. If anyone know, please help us out
