November 1, 2006, 06:03 |
Propeller torque
Hi everyone, i've computed a solution for a propeller using a single rotating reference frame, i.e. the propeller is stationary and the flow rotates about the propeller. I need thrust and torque parameters, and am comparing these to experimental values.
The thrust was found from: Report-->Forces, and specifying the direction of thrust. This is a reasonable result. Because the flow is rotational and the blade is stationary, i'm not sure I can just report a force in torque (drag) direction of the propeller blades. Is there any way to report a result in a different reference frame? or is there a standard method in determining the Torque of a propeller blade? Thankyou in advance! Alex. |
November 1, 2006, 06:18 |
Re: Propeller torque
My apologies, torque is a moment of course. too late at night.
Well this makes my question much simpler: when you report the moment about the specified axis, the results are presented as: (number1, number2, number3). Does this represent moments about (x,y,z) axes? i.e. does "number3" represents the torque about the z-axis? thanks, Alex. |
Propeller calculation | toil | CFX | 15 | May 22, 2017 04:06 |
Thrust and torque of a propeller | Alex H | FLUENT | 3 | July 1, 2016 17:00 |
Torque calculation of 2D VAWT Wind Turbine | Anonymized_JL1 | FLUENT | 14 | September 26, 2013 03:35 |
Modelling a propeller | tomg | STAR-CCM+ | 4 | April 28, 2011 17:22 |
about use macro to compute torque in TASCflow | lancy | CFX | 0 | June 10, 2003 06:19 |
