November 2, 2006, 14:45 |
interface boundary condition definitions?
Hi All, I am modeling a simple problem, a baseball moving in a duct of air. I am imposing the flow on the ball (so the ball is stationary) and a rotational boundary condition on the ball (stationary but spinning). Was told to use an interface boundary condition on the ball, but Fluent spits out htat this condition is undefined. Any help? thanks
November 2, 2006, 15:47 |
Re: interface boundary condition definitions?
The ball itself is a wall... I think what they were telling you to do was to split a sphere from the main volume (connected option off) which was larger than the ball, add a spin to this volume, and then use an interface BC where the two volumes connect. An interface BC always needs a matching interface BC and then you need to tell Fluent to connect the two interfaces.
If you have split the volumes, then you must Define->Grid Interfaces (don't worry about coupled or periodic option, it's a straight forward interface). The other option is to not bother with splitting the volume and define the wall of the ball as spinning. Good luck, Jason |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Interface boundary condition | engahmed | FLUENT | 66 | September 6, 2017 10:30 |
Slip boundary condition what is inside | normunds | OpenFOAM Running, Solving & CFD | 2 | June 4, 2007 06:45 |
Rotating interpolated boundary condition | hani | OpenFOAM Running, Solving & CFD | 0 | July 4, 2006 07:09 |
New topic on same subject - Flow around race car | Tudor Miron | CFX | 15 | April 2, 2004 06:18 |
