December 12, 2006, 02:35 |
Fluent error
Error messagae goes like this: skipping zone *name of the boundary condition (not refrenced by grid)
Do anyone know what is the problem? |
December 12, 2006, 03:23 |
Re: Fluent error
i think you meshes a face, which was not the part of the volume, so when the mesh was exported the face mesh (not connected to any volume) also exported. In the mesh it is like a surface mesh. Fluent sees this and skips, since its not referenced by any zone (fluid or solid, ie in volumes in gambits terms). If you try to read only surface meshes, fluent will give you error.
Anyway best way to check what went wrong is plot wall in grid display, you will see a wall at the place you thought this surface should be. |
December 12, 2006, 07:13 |
Re: Fluent error
i am also having this problem when using periodic boundary conditions in the streamwise and spanwise directions for turbulent channel flow. Any idea how to resolve this problem??
December 12, 2006, 23:06 |
Re: Fluent error
what exactly is the error message. I only guesses based on the error message the OP said.
December 29, 2006, 04:09 |
Re: Fluent error
The error is cx-xy-append-data: invalid number (y). I do not know how to set the boundary condition and operation condition when I will simulation. Help me!
December 30, 2006, 09:37 |
x-y plane error mesh
hi, i can someomne help me with this, i am having this error in gambit;all mesh nodes must lie on the XY plane within tolerance, my gambit drawing is 2 volumes united together with a fan bellmouth which i drew using vertex and revolving it. you can reply through my email add;yakubu@sun.ac.za, your response is well appreciaciated
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
error while running paraFoam! | padmanathan | OpenFOAM | 9 | October 13, 2009 05:17 |
Installation OF1.5-dev | ttdtud | OpenFOAM Installation | 46 | May 5, 2009 02:32 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
