December 29, 2006, 07:14 |
NEGETIVE VOLUME
Hi i am modeling reciprocating compressor by dynamic meshing (cylinder piston arrangement).
lenght of compressor is=0.0075m radius=r=0.00954m my udf function for piston is frequency = f=34hz w=2*Pi*f=213.62rad/s displacement of piston is X= 4.511e-3m piston head velocity =V= 0.9631Cos(w t) i am taking time step=dt= 7.3529e-4s no of time steps = 40 I am getting negative volume problem as follow Error: Update-Dynamic-Mesh failed. Negative cell volume detected. Error Object: () How to solve this problem.Waiting for your kind suggestions? ammi reddy |
January 3, 2007, 07:10 |
Re: NEGETIVE VOLUME
Hi Ammi, check your cell sizes in respect to the moving wall velocity. usually you get the statement as soon as the moving cellwall and the stationary wall overlap. kais
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
