January 4, 2007, 08:44 |
Please help, urgent
I previously asked about using LES to simulate channel flow and was curious of how to initiate the turbulence. I recieved this message back
If you are running LES, why you don't use in the inlet one of the Fluctuation Velocity Algorith; you have the Vortex Method and the Spectral Synthesizer. In the Vortex method, for example, you can specify a number of Vortices in the inlet. Then you have a turbulence Specification method and there you can use k and epsilon (from RANS), turbulent intensity, length scale, viscosity radio, etc. Good luck Hugo Could anybody elaborate on how i should do this please i am running out of time. Thanks in advance David |
Urgent - Polyflow - particle tracking visualization -Urgent | shafaatht | ANSYS | 0 | October 13, 2010 04:56 |
Urgent, Urgent, a UDF problem, PLEASE HELP!!! | Max | FLUENT | 1 | September 24, 2010 20:30 |
Urgent...urgent...plss!!! | astronome | FLUENT | 0 | October 16, 2009 07:17 |
tmerge urgent urgent | jessica | FLUENT | 4 | July 15, 2006 13:37 |
very urgent pleasade:Cl and Cd values for airfoil | Liaquat | FLUENT | 2 | April 27, 2006 12:20 |
