January 8, 2007, 05:37 |
Error in Gambit
In Gambit, when I am trying to convert surface mesh to solid mesh, it gives me error
- Initialization failed; perturb boundary nodes and try again I tried all kinds of interval size, I cant able fix this problem. Can anybody help me on this? More over I don't T-Grid software to convert surface mesh to solid mesh. |
January 9, 2007, 04:32 |
Re: Error in Gambit
check the skewness of the surface mesh.. this generally is the problem... if the geometry is complicated, you can chk if regions with small gaps have adequate mesh density!!
January 9, 2007, 04:35 |
Re: Error in Gambit
Thanks Pratik
What is the range of Skewness value we are supposed to have in the surface mesh? How to check the same in Gambit? |
[ANSYS Meshing] Migrating from GAMBIT to ANSYS Meshing | David-CFD | ANSYS Meshing & Geometry | 1 | April 1, 2011 05:22 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 06:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 12:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 08:33 |
3-D Mesh Check in Gambit..... | SHR | FLUENT | 4 | March 25, 2003 03:10 |
