September 1, 2009, 08:20 |
Error while compliling an UDF
Kappe
Rep Power: 16 |
Hi I have written an UDF to oscillate my geometry. When i complie it i have the fluent says:
1 file(s) copied. ( the UDF.c file) 1 file(s) copied.( udf.h) 1 file(s) copied.(metric.h) (system "copy C:\Fluent.Inc\fluent6.2.16\src\makefile_nt.udf libudf\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf")() (chdir "ntx86\2ddp")() UDF.c e:\shreyas\naca0012\unstructured\libudf\src\udf.c( 27) : warning C4700: uninitialized local variable 'node' used # Generating udf_names.c because of makefile UDF.obj Done. Opening library "libudf"... Error: open_udf_library: The system cannot find the file specified. Error Object: () THE LOG FILE SAYS: sed' is not recognized as an internal or external command, operable program or batch file. NMAKE : U1077: 'C:\WINDOWS\system32\cmd.exe' : return code '0x1' Stop. PLZ HELP!!!!! my UDF is #include "udf.h" #include "metric.h" DEFINE_CG_MOTION(Oscillation, dt, vel, omega, time, dtime) { face_t f; Thread *tf = DT_THREAD(dt); real xn, yn, r, sin_theta, cos_theta; int n; begin_f_loop(f,tf) /* Loops over all faces in the thread passed in the DEFINE macro argument */ { f_node_loop(f,tf,n) /* Loops over all nodes in the face */ { Node *node; xn = NODE_X(node); // calculate x-coordinate of a grid point on wall yn = NODE_Y(node); // calculate y-coordinate of a grid point on wall r = sqrt(pow(xn,2)+pow(yn,2)); // calculate radial coordinate of the grid point on wall sin_theta = yn/r; cos_theta = xn/r; vel[1]=cos(3.14159*time)*cos_theta*0.087266463*3.14159*r ; //y-component of velocity vel[0]= cos(3.14159*time)*sin_theta*0.087266463*3.14159*r; //x-component of velocity } } end_f_loop(f,tf); } |
June 23, 2011, 17:53 |
#2 | |
Rep Power: 15 |
Hi, have you figured out the way to eliminate the "warning C4700: uninitialized local variable 'node' used"?
I have the same problem in mu UDF, can you please share your experience with me? Thanks! Quote:
June 24, 2011, 09:04 |
John Palmore
Rep Power: 15 |
To me it looks like the variable node has not been declared properly. I think your code should look something like this:
Node *node; begin_f_loop(f,tf) /* Loops over all faces in the thread passed in the DEFINE macro argument */ { f_node_loop(f,tf,node) /* Loops over all nodes in the face */ { xn = NODE_X(node); // calculate x-coordinate of a grid point on wall yn = NODE_Y(node); // calculate y-coordinate of a grid point on wall ... |
June 27, 2011, 20:59 |
Tobino
Rep Power: 15 |
I am too using UDF, your code not problem may be you not complete in creating environment for Fluent to connect with C programme. |
June 28, 2011, 17:34 |
Problem with six_dof.h
Turan Colak
Dear Friends;
I'd faced a problem with my six_dof.h file. I'd build an UDF file that used sdof_properties macro, fluent returned a parse error. I've checked some other macros such as velocity, boundary it works fine. But when i used dynamic mesh macros, get parse errors. I tried "#include six_dof.h" option and received parse error at line 69. Is there any body faced with this before or knows solution. thanks.. |
June 30, 2011, 09:46 |
Adrien Lemoine
Rep Power: 14 |
here is your UDF (corrected from line 21 to 26) and it s working on my computer. UDF : #include "udf.h" #include "metric.h" DEFINE_CG_MOTION(Oscillation, dt, vel, omega, time, dtime) { face_t f; Thread *tf = DT_THREAD(dt); real xn, yn, r, sin_theta, cos_theta; int n; begin_f_loop(f,tf) /* Loops over all faces in the thread passed in the DEFINE macro argument */ { f_node_loop(f,tf,n) /* Loops over all nodes in the face */ { Node *node; xn = NODE_X(node); /* calculate x-coordinate of a grid point on wall */ yn = NODE_Y(node); /* calculate y-coordinate of a grid point on wall */ r = sqrt(pow(xn,2)+pow(yn,2)); /* calculate radial coordinate of the grid point on wall */ sin_theta = yn/r; cos_theta = xn/r; vel[1]=cos(3.14159*time)*cos_theta*0.087266463*3.14159*r ; /*y-component of velocity */ vel[0]= cos(3.14159*time)*sin_theta*0.087266463*3.14159*r; /*x-component of velocity */ } } end_f_loop(f,tf); } (DON'T FORGET TO USE dos2unix fonction if using Unix) Sincerly Adrien Plz add reputation if the answer is correct |
July 1, 2011, 00:14 |
#7 | |
Rep Power: 15 |
Hi AdrienL,
Can you please take a look at my UDF?I want to model a filter (but not modeling it as a porous media), in a room I have SO2 and air mixture. First I want to get the SO2 mass flow rate at the inlet surface of the filter, then multiply it by 0.999989, and set the sink rate of the filter volume as -0.999989*(SO2 mass flow rate at the inlet surface)/(Volume of filter). For the outlet of the filter, I set it as "interior", and my simulation is always transient. The error I got for parallel computing is: 999999 (..\src\mpsystem.c@1149): mpt_read: failed: errno = 10054 999999: mpt_read: error: read failed trying to read 4 bytes: No such file or directory MPI Application rank 0 exited before MPI_Finalize() with status -1073741819 If I switched to serial computing, the error I got is: Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: #f I don't know what I wrote wrong,,, #include "udf.h" #define inlet_surface_ID 70 #define filter_volume_ID 3 DEFINE_ADJUST(my_adjust, d) { int i=0; real massflowrate=0.; real vol=0.; #if !RP_HOST /* real A[ND_ND]; */ /* real flux[ND_ND]; */ real NV_VEC(flux); real NV_VEC(A); /* declaring vectors flux and A */ real source; /* real ti = RP_Get_Real("flow-time"); */ /* ti = CURRENT_TIME;*/ face_t f; cell_t c; Thread *t; Thread *thread; /* vol=0.0; */ /* massflowrate=0.0; */ t = Lookup_Thread(d, inlet_surface_ID); /* defining the inlet surface thread by specifying the Zone_ID*/ thread= Lookup_Thread(d, filter_volume_ID); /* defining the filter volume thread by specifying the Zone_ID*/ /* Send the ID value to all the nodes */ /* host_to_node_real_4(f, t, c, thread); Does nothing in serial, t is the thread of inlet surface, thread is the thread of the filter volume */ /*Start to calculate the mass flow rate through the inlet surface and store it in UDM*/ begin_f_loop(f,t) if PRINCIPAL_FACE_P(f,t) /* tests if the face is the principle face FOR COMPILED UDFs ONLY */ { /* NV_D(flux, =, F_U(f,t), F_V(f,t), F_W(f,t)); */ /* defining flux in terms of velocity field */ /* NV_S(flux, *=, F_R(f,t)); */ /* multiplying density to get flux vector */ /* F_AREA(A,f,t); */ /* face normal vector returned from F_AREA */ /* i is being used uninitialized. Please fix this */ massflowrate += F_FLUX(f,t)*F_YI(f,t,i); /* dot product of the inlet surface flux and area vector, multiplied by the mass fraction of species i */ } end_f_loop(f,t) # if RP_NODE /* Perform node synchronized actions here, Does nothing in Serial */ massflowrate = PRF_GRSUM1(massflowrate); # endif /* RP_NODE */ begin_f_loop(f,t) if PRINCIPAL_FACE_P(f,t) /* tests if the face is the principle face FOR COMPILED UDFs ONLY */ { F_UDMI(f, t, 0)= massflowrate; /* YOU MAY NEED TO CHECK THE NODE AS THE SUMMED UP VALUE OF massflowrate IS DONE AT node0. */ } end_f_loop(f,t) #if RP_NODE0 Message0("Inlet TEP Mass Flow Rate through %d is: %g \n", inlet_surface_ID, massflowrate); #endif /*Start to calculate the total volume of filter volume and store it in UDM */ begin_c_loop(c,thread) { vol += C_VOLUME(c,thread); /* get cell volume */ } end_c_loop_int(c,thread) #if RP_NODE /* Perform node synchronized actions here, Does nothing in Serial */ vol= PRF_GRSUM1(vol); # endif /* RP_NODE */ begin_c_loop_int(c,thread) { C_UDMI(c, thread, 1)= vol; /* YOU MAY NEED TO CHECK THE NODE AS THE SUMMED UP VALUE OF massflowrate IS DONE AT node0. */ } end_c_loop_int(c,thread) #if RP_NODE0 Message0("Sink Volume in %d is: %g \n", filter_volume_ID, vol); #endif #endif } DEFINE_SOURCE(cell_tepmass_source, c, thread, dS, eqn) { real source=0.; real tepflowrate=0.; real vol_tot=0.; #if !RP_HOST /* real ti = RP_Get_Real("flow-time"); /\* ti = CURRENT_TIME;*\/ */ face_t f=0; Thread *t; /* Thread *thread; */ Domain *d = Get_Domain(1); t= Lookup_Thread(d, inlet_surface_ID); /* defining the inlet surface thread by specifying the Zone_ID*/ thread= Lookup_Thread(d, filter_volume_ID); /* defining the filter volume thread by specifying the Zone_ID*/ /* f is being utilized without initialization. This will lead to errors.Please fix this issue */ /* instead of F_UDMI, you can store data in C_UDMI */ tepflowrate= F_UDMI(f, t, 0); vol_tot = C_UDMI(c, thread, 1); #endif /* Pass the node's TEP mass flow rate and volume to the Host for calculating source */ node_to_host_real_2(tepflowrate, vol_tot); /* Does nothing in SERIAL */ #if !RP_NODE source=0.999989*tepflowrate/vol_tot; dS[eqn]=0.; Message("Sink Rate in Filter %d is %g (kg/m^3/s)\n", filter_volume_ID,source); #endif return source; } Quote:
Display Modes | |
Dynamic Mesh UDF | Qureshi | FLUENT | 7 | March 23, 2017 07:37 |
UDF parallel error: chip-exec: function not found????? | shankara.2 | Fluent UDF and Scheme Programming | 1 | January 16, 2012 22:14 |
How to add a UDF to a compiled UDF library | kim | FLUENT | 3 | October 26, 2011 21:38 |
UDF...UDF...UDF...UDF | Luc SEMINEL | FLUENT | 0 | November 25, 2002 04:03 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
