BC in Fluent
Old   January 15, 2007, 15:08
Default BC in Fluent
cent
Hello, I want to compute drop of pressure in hydraulic quick coupling. How can I assign Mass Flow Inlet to set up Boundary Condition?? Thanks
Old   January 16, 2007, 02:38
Default Re: BC in Fluent
Carlos
Hi, if you are using Gambit then you simply need to set the appropriate boundary condition. If you click the "Zones Command Button" in the top right of the GUI, then click "Specify Boundary Types" you can select the boundary conditions. Simply change the type to MASS_FLOW_INLET from the list and assign that to the face(s) which you want to have this boundary condition.
Hope this helps!
Carlos.
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
A Problem of Fluent Interpreted UDF: parse error knight Fluent UDF and Scheme Programming 25 August 16, 2018 10:26
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Compared MRFSimpleFoam and Fluent in a centrifugal pump! renyun0511 OpenFOAM Running, Solving & CFD 8 July 6, 2010 06:24
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
