Peculiar Strouhal Number in FLUENT
Old   April 15, 2014, 04:36
Default Peculiar Strouhal Number in FLUENT
pizzaspinate is on a distinguished road
Dear all,
I am currently analysing the noise generated by a rod-airfoil configuration in ansys fluent. For the geometry and domain I used the dimensions given in a paper.
When I use FFT to plot Strouhal number against PSD I get St numbers in a range from 0-10,000. I do not understand what I did wrong, so it would be great if someone could help me out.
Thank you very much in advance.
pizzaspinate is offline   Reply With Quote
Flow past a cylinder, Reynolds No: 100, Tracking strouhal Number. Karan FLUENT 11 November 14, 2016 04:49
number of iterations to converge solution in Fluent as Ansys Workbench output param nnvoro FLUENT 4 May 2, 2013 01:18
low reynolds number models in Fluent doug Main CFD Forum 6 August 4, 2012 14:39
DecomposePar unequal number of shared faces maka OpenFOAM Pre-Processing 6 August 12, 2010 09:01
Unaligned accesses on IA64 andre OpenFOAM 5 June 23, 2008 10:37
