Isometric View?
Old   January 14, 2007, 05:07
Default Isometric View?
linus chia
Hi there! After running simulations in FLUENT, is there any command which i can execute so that i can view my model in an isometric view?
Thanks!
Old   January 16, 2007, 00:44
Default Re: Isometric View?
sudhakar
go to disply -grid,there select,you select out line in edge type.u will get isometric view in out line,
Old   January 16, 2007, 08:48
Jason
There are pre-defined camera angles... Dislpay->Views... you'll see them there.
Good luck, Jason
Old   January 16, 2007, 18:11
linus
hi jason,
thanks for your reply.. i managed to see them there, i.e, 'display->views', but how do i actually see, for example, the contours of static temperature for my simulation?
best regards, linus
View particle trajectory in CFD View xonix Main CFD Forum 1 April 25, 2011 23:40
S2S radiation - view factor file error Tolis FLUENT 1 May 12, 2009 06:17
isometric view? linus FLUENT 1 February 14, 2007 02:06
Fluent - View Factor for s2s radiation Markus FLUENT 1 October 16, 2005 01:33
view rotation in provis Anna (aka new-user) Siemens 3 November 19, 2004 08:45
