January 18, 2007, 02:43 |
Differents fluids separated by wall
Hello everyone,
I have different fluids (lets says a dozen!), all of them separated by a wall. So I have 12 fluids separated by 11 wall. There is heat exchange in these 11 walls. The fluids are totally differents : water, oil, anything you want... and I want to use gravity. At this step, I have a first issue : (1) I can't define different operating density for each fluid, can I ? Now one of these 12 fluids requires "solidification/melting" because there is a phase change at 330K. For this fluid there is no velocity inlet and outflow, this fluid can't go away, there is only walls around it. I need "gravity" to compute natural convection in the liquid phase. If I want to use the Boussinesq hypothesis, I redefine the material, and I give a value for the Boussinesq density, and the thermal expansion coefficient "beta" (so the operating density will not apply for this fluid, am I right ?) But now, I have an issue when I use Boussinesq with solidification/melting, I can give only one value for the density. But the density of the solid phase is not the same than the liquid phase (there is 10% volume expansion between liquid/solid) !!! (2) Is there no way to use Boussinesq for the liquid phase, and a different density for the solid phase ? Can anyone insure me that it is not possible to do that with fluent ? or tell me if I missed something... Thanx a lot. |
UDF to Access Wall Normal Concentration Gradient | Daniel Tanner | Fluent UDF and Scheme Programming | 4 | February 18, 2015 14:35 |
[Commercial meshers] tmerge utility creates unwanted interface/walls comes in the final mesh | Shoonya | OpenFOAM Meshing & Mesh Conversion | 11 | January 20, 2012 06:23 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
Tomiyama wall lubrication force | Edy | OpenFOAM | 10 | December 13, 2010 11:41 |
Influece of wall velocity in the main flow | marvin | CFX | 0 | March 22, 2008 02:05 |
