Turbulence kinetic energy formula
Old   January 25, 2007, 01:56
Default Turbulence kinetic energy formula
ranjit
after i turn on the turbulence k-epsilon model, while specifying the inflow velocity for air, fluent asks for "turbulence kinetic energy" and "turbulence dissipation rate". Both are given the default values of 1.
Is there any formula to calculate these values. Can it be calculated from Reynold's number, properties of air etc..
Please help..
Old   January 25, 2007, 14:36
Default Re: Turbulence kinetic energy formula
Sujith
The definition can be found here http://www.cfd-online.com/Wiki/The_F...Kinetic_Energy
For simulations the default values are very high and often leads to convergence troubles..
You may use .1 or lesser values for both.
Instead to TKE and e, you can select the turbulent specification method as Intensity and hydraulic diameter, which are easier to estimate.
k-e turbulence model and energy equation Blob Main CFD Forum 0 May 29, 2009 08:35
Tubulence kinetic energy Alex CFX 0 September 21, 2007 03:32
kinetic energy in k-e dispersed turbulence model? tim FLUENT 0 March 29, 2007 14:24
turbulence kinetic energy? Eric FLUENT 1 December 3, 2000 10:41
turbulence modeling questions llowen Main CFD Forum 3 September 11, 1998 04:24
