January 27, 2007, 18:51 |
Laminar flow or Turbulent flow
Hello
I am doing a research about heat transfer on dimpled plate. Air flow condition is laminar flow region (Re1500~3000) So, I chose laminar flow for viscose setting. I checked flow velocity inside of dimple. I expect that there would be vortex inside of dimple. But, there is almost no effect of dimples. In that case, can I use turbulent flow to check the vortex? If I use turbulent flow model, which model can I use? (k-e or LES) Thank you |
Turbulent viscosity in Laminar Flow | Mike | Main CFD Forum | 8 | April 12, 2010 11:40 |
turbulent flow turns to transition and then to laminar | asalama | CFX | 7 | April 2, 2010 06:19 |
Reynolds and Turbulent flow | Frederic Dubinski | CFX | 5 | October 21, 2004 04:12 |
laminar or turbulent | wood | Main CFD Forum | 8 | October 20, 1999 22:03 |
