Nozzle flow simulation in inviscid and viscous |
January 28, 2007, 02:16 |
Hello people! I'm using Fluent to calculate a Laval nozzle flow in 2D with air, with coupled implicit solver in a steady case. I'm trying to see the case of subsonic-supersonic with a normal shock wave. The inviscid model gives a normal shock wave inside the nozzle but when I use the Spallart-Allmaras model for viscosity (used in the Fluent tutorial for compressible flow, someone can tell me why this model?), I have some weird results. If I use a courant number of 5 (default value), I do not have any shock wave and the residuals oscillates around 1e-01. If I begin with a small Courant number (0.01) and then I increase it to 40 gradually, I have a normal shock wave, far upstream in the divergent part of the nozzle compared to the inviscid case. The residuals are under 1e-3. Moreover, there is a recirculation zone just after the shock. Can someone tell which result to believe? I am very confused... Thanks in advance for your help.
inviscid flow and turbulnces | sylvain | Main CFD Forum | 5 | August 2, 2013 16:48 |
SIMPLE method for inviscid flow | abcdef123 | Main CFD Forum | 0 | February 26, 2010 08:24 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 05:44 |
flow simulation across a small fan | jane luo | Main CFD Forum | 15 | April 12, 2004 17:49 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
