January 25, 2007, 02:46 |
cycle average temp
hi
I am doing cfd analysis of a pulse tube refriegaror. In this project their is cylinder piston arangement and other parts are their. the piston vecocity is given by V=.09 COS(213t) their is a change in temp in different part as simulation going on. how to got the graph between cyle average temp ~ time ? not static ~time please reply ammi |
January 29, 2007, 13:52 |
Re: cycle average temp
Hi Ammi, This is not striaght forward to accomplish using Fluent alone. The way I would recommend working around this is to use surface monitors. Define a monitor at the surface where you would like the average temperature. (Solve--> Surface Monitors). Then go on to define the Y-axis as "Flow time"
Doing the above will record your time varying data into a monitor file. At the end of your simulation you can use Matlab, Excel or techplot to plot your results! Good luck, Phil |
Floating point exception error | Alan | OpenFOAM Running, Solving & CFD | 11 | July 1, 2021 21:51 |
Average Facet, Surface Vertex or Area-Weighted | Emmanuel | FLUENT | 3 | March 27, 2020 10:55 |
Udf function average temp inlet - outlet | erodv | FLUENT | 4 | October 6, 2017 11:16 |
Passing Average Temp from Outlet to Inlet | Steve Scotts | FLUENT | 1 | August 27, 2008 05:02 |
how to find cycle average temp | ammi | FLUENT | 0 | January 22, 2007 03:01 |
