Contours
Old   January 24, 2007, 02:04
Default Contours
Sangeeta
After iterating , i get temperature contours discreet. Can i know what could be the problem?
Old   January 24, 2007, 02:57
Default Re: Contours
sachin
can you expedite what is actually contours showing?
Sachin
Old   January 24, 2007, 04:12
Sangeeta
No, I cant
Old   January 24, 2007, 07:22
Akshay
May be I can suggest you something if you could tell me what are you doing?Are you able to iterate successfully?is your solution converged?is your mass is conserved?
what i understand is, you ahve successfully iterated, and you get this as a error when you try to display contours of temperature or velocity.
Do you mean to display it as a filled temperature option?
Old   January 24, 2007, 11:24
Sangeeta
I am using fluent to model Inductively coupled plasma. It was sucessfully iterated and converged. Only Temp and velocity contours (filled) showd discete contours. Can i know the reason.
I dont have background of Fliud Dynamics.
Old   January 24, 2007, 15:29
Sujith
If the problem is getting the discrete values at each cells instead of a continuously varying contour across cells, you may not have turned on the nodal values in the display contours option.
Old   January 25, 2007, 08:11
Jason
Increase the number of contour ranges from 20 to 100. That'll smooth out the plot. Also make sure nodal values is selected.
Good luck, Jason
Old   January 26, 2007, 04:57
Sangeeta
Thanks
Old   January 28, 2007, 10:55
Sangeeta
I have tried clicking node values and ranges also but the problem still exits.(Coutour shows some lines and some dots)
Old   January 29, 2007, 12:42
mmacrb
can you send me the case and dat files so i check what is the problem
my email is bhuttathermo@yahoo.com
Old   January 30, 2007, 11:21
  #11
Jason
Have you turned on "filled"?
Jason
Old   January 31, 2007, 01:16
  #12
Sangeeta
Yes i have done that
Urgent! how to plot contours without grid in the figure? ivanbuz FLUENT 11 November 10, 2009 21:44
Turbo contours Max n Min Values Sans CFX 2 May 31, 2008 04:22
Contours ( please advice) HAR FLUENT 0 May 31, 2006 19:40
Preconditioning and pressure contours ganesh Main CFD Forum 2 February 18, 2006 00:02
extension for liquid fraction contours venugopal FLUENT 0 June 11, 2004 01:27
