BOUNDARY CONDITION
Old   February 1, 2007, 04:24
Default BOUNDARY CONDITION
brusly
hi i am solving one mixing problem.for that i have two inlets and one outlet.two inlet having different fluids so how can i specify the different fluids in different inlets.
Old   February 3, 2007, 01:04
Default Re: BOUNDARY CONDITION
Swarup
It is a mixing problem. Form the mixture material made up of n fluids you are using. Then, at inlet you will be asked to specify the mass fractions of first (n-1) fluids in the mixture. Specify accordingly. The mass fractions of n fluids of the mixture should some to 1.0.
Swarup.
Old   February 3, 2007, 03:51
brusly
thank u swarup i will look up
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Boundary Conditions Thomas P. Abraham Main CFD Forum 20 July 7, 2013 05:05
Setting outlet Pressure boundary condition using CAFFA code Mukund Pondkule Main CFD Forum 0 March 16, 2011 03:23
How exactly the "pressure outlet" bdry condition compute properties on the boundary? yating9901 FLUENT 3 June 28, 2010 12:26
How to set boundary condition in Fluent for the fo Peiyong FLUENT 1 November 10, 2006 11:44
