February 3, 2007, 02:33 |
Gambit: non-conformal facets?
When trying to mesh an airfoil shaped vane, I get the following message: "Warn: Failed to generate conformal facets for vane1, using non-conformal facets instead." I assume this means that the mesh for the vane will be non-conformal, which I'd like to avoid if possible.
I have tried to simplify the geometry as much as possible. The part consists of an annulus with a set of airfoil shaped vanes in the annulus to swirl the airflow. Each vane is connected to the inner and outer wall of the annulus via a small fillet. I am using a curvature based sizing function to vary the mesh size as the curvature changes on the vane. Any suggestions? |
Display Modes | |
Converting Fluent mesh files to Gambit neutral files | samuelkc | ANSYS Meshing & Geometry | 9 | April 21, 2021 07:28 |
Gambit help: Cube inside cube | Jack Martinez | FLUENT | 13 | August 11, 2010 07:29 |
Gambit 2.3.16, Xming or Exceed...HELP! | bambam3417 | FLUENT | 10 | May 7, 2010 13:39 |
Gambit -dev X11 doesn't work | Ervin Amet | FLUENT | 0 | October 28, 2007 09:33 |
between IDL Gambit and rhino, any help? | philip | FLUENT | 0 | June 23, 2005 13:08 |
