January 24, 2007, 23:27 |
orifice problem
hi
i amnew to fluent. In my problem fluid is flowing through pipe but their is a orifice in the pipe closing 25 percent of cs area. how to define it in fluent ans where to define ? waiting for ur reply thanks RENUKA |
January 25, 2007, 02:54 |
Re: orifice problem
u make changes in the geometry (pipe) to reduce the cross section by 25%.
i mean add hollow cicular plate with the hollow area equal to the orffice hole area at the point where the orffice is located. |
January 25, 2007, 03:07 |
Re: orifice problem
Thanks rams for ur reply
My problem is 2d one . what i got some previous paper is that orifice canbe modleded as flow restriction . their is a value k whose has to mention in flunt but where i dont know if u have any idea please reply kamini |
January 25, 2007, 11:23 |
Re: orifice problem
what are u asking for i don't know please be a little clear
January 31, 2007, 15:51 |
Re: orifice problem
Do you mean a orifice plate? If not, then there is no problem with just creating it as a single orifice.
February 3, 2007, 18:15 |
Re: orifice problem
Dear sir
I am trying to model variable area orifice meter, the methodology is to use bluff body against the flow direction, and the system is connected to water tank 15m above the orifice level. My question how much I have to identify the operation pressure or I can use the atmospheric pressure. Thanks The configuration in this link http://public.cranfield.ac.uk/me/me028/courses/process/ |
February 5, 2007, 00:39 |
Re: orifice problem
I guess u would be modelling only pipe flow with a variable area orifice meter, if then specify operating pressure a the pressure calculated at the point 15m below the water tank,
if u r including the modelling of water tank then take it as atmospheric pressure |
Problem with interFoam; Wave/wiggle alpha1 behavior | JonW | OpenFOAM | 10 | February 4, 2023 07:27 |
Gambit - meshing over airfoil wrapping (?) problem | JFDC | FLUENT | 1 | July 11, 2011 05:59 |
Problem in implementing cht | tilek | CFX | 3 | May 8, 2011 08:39 |
Adiabatic and Rotating wall (Convection problem) | ParodDav | CFX | 5 | April 29, 2007 19:13 |
Is this problem well posed? | Thomas P. Abraham | Main CFD Forum | 5 | September 8, 1999 14:52 |
