fluent on fedora core 6
Old   December 31, 2006, 09:15
Default fluent on fedora core 6
Jeferson
Does anybody has fluent working on fedora core 5 or 6. On both releases, when I try to start fluent software I have the folowing error message: ************* Loading "/opt/Fluent.Inc/fluent6.3.26/lib/flprim.dmp.1119-32" Done. /opt/Fluent.Inc/fluent6.3.26/bin/fluent: line 4820: 5057 Segmentation fault
EOF on stdout. The fluent process could not be started. *************
Does anyone knows how to solve this problem?
Old   January 19, 2007, 09:04
Default Re: fluent on fedora core 6
Akshay
Fedora core is not a supported platform for Fluent. If you are licensed user, ask your vendor to send you a list of supported platforms.
Old   January 22, 2007, 14:36
zkw
Fluent can be run in mathing bash version, no matter what Linux distribution is used. Fluent 6.2 and 6.3 require bash 3.0 version.
Old   February 4, 2007, 02:25
DH
Originally fluent needed the 2.4 series kernel but with the launch of the most recently supported Redhat Enterprise version the kernel is up to the 2.6 series. This in combo with a bash 3.0 variant will allow you to run fluent on fedora core 4. I have had the bash issue on FC5 and FC6, there is a fix for it if you google suse and fluent and CFD.
Cheers,
DH
Old   February 5, 2007, 12:33
Jeferson Avila Souza
I tried the fix proposed in the link http://www.suseitalia.org/modules/ne...forumpost32653, but it does not work. I still having the same erro of EOF.
Old   February 5, 2007, 12:45
Dh
Please follow these instructions for running on suse, a similar process should be followed for FC variants.
http://en.opensuse.og/Running_FLUENT_6.2_on_SuSE_10.1.
Old   February 5, 2007, 12:47
Dh
links apparently has problems from this page but it is there if you google the following
suse + Fluent + bash
http://en.opensuse.org/Running_FLUENT_6.2_on_SuSE_10.1.
the link is just missing underscores in the last post should be
Old   February 9, 2007, 14:43
I don't know why, but it did not work on my fedora core 6 system!
solving a conduction problem in FLUENT using UDF Avin2407 Fluent UDF and Scheme Programming 1 March 13, 2015 02:02
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
Master node in parallel computing only distirubtion syadgar FLUENT 1 September 8, 2009 16:41
FoamX Error after upgrade to Fedora Core 6 philippose OpenFOAM Installation 5 October 31, 2006 12:36
fluent amd 64 and fedora core 5 nikos FLUENT 1 April 11, 2006 09:21
