Fluent doesn´t compile UDF on Windows
Old   February 8, 2007, 22:23
Default Fluent doesn´t compile UDF on Windows
HSeldon
Hi all, I´m having problems with Windows. Basically, I can´t compile UDFs. I have Microsoft Visual Studio 6 installed.
I know that the UDF is ok because I can compile it without problems in Suse.
Old   February 9, 2007, 00:10
Default Re: Fluent doesn´t compile UDF on Windows
chakradhar
HELLO!!! hseldon in order to run your udf you to create a directory named libudf in C DRIVE and save your ".c" in that directory it will work.
Old   February 9, 2007, 00:44
HSeldon
Thank you for the input! Tried it but it still doesn´t work...
Old   February 10, 2007, 14:42
Antoine
If you want to compile your udf with Fluent using the Microsoft Visual Studio 6, you have to set the environment variables in Windows. So add the four variables as below (where for each variable the first line is the variable and the other lines constitue the value):
include C:\Program Files\Microsoft Visual Studio\VC98\ATL\Include;C:\Program Files\Microsoft Visual Studio\VC98\MFC\Include;C:\Program Files\Microsoft Visual Studio\VC98\Include
lib C:\Program Files\Microsoft Visual Studio\VC98\MFC\Lib;C:\Program Files\Microsoft Visual Studio\VC98\Lib
MSDevDir C:\Program Files\Microsoft Visual Studio\Common\MSDev98
path C:\Program Files\Microsoft Visual Studio\Common\Tools\WinNT;C:\Program Files\Microsoft Visual Studio\Common\MSDev98\Bin;C:\Program Files\Microsoft Visual Studio\Common\Tools;C:\Program Files\Microsoft Visual Studio\VC98\Bin
Old   February 14, 2007, 23:01
Ali
I have some problem with compiling a udf which is exactly the example of fluent itself for surface reaction.
I use DEFINE_SR_RATE( ..... ) I tried to interprete it but it has problem with wherever I have r->name or structure type data. with compiling I cant compile at all the error is like this :
Deleted old libudf1\ntx86\2ddp\libudf.dll The system cannot find the file specified.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied.
1 file(s) copied. (system "copy C:\CFD\Fluent621.Inc\fluent6.2.16\src\makefile_nt. udf libudf1\ntx86\2ddp\makefile") 1 file(s) copied. 0 (chdir "libudf1")() (chdir "ntx86\2ddp")() 'nmake' is not recognized as an internal or external command, operable program or batch file. 'nmake' is not recognized as an internal or external command, operable program or batch file.
Done.
Interrupting... Done.
Would you please help me, I really need help
Fluent does not always compile UDF properly davesmith_01 Fluent UDF and Scheme Programming 3 February 10, 2011 14:09
UDF in Fluent subha_meter Main CFD Forum 0 October 17, 2009 23:54
Compiling UDF in Fluent 12 jsm FLUENT 1 July 22, 2009 07:40
Any Luck with 64-bit FLUENT on 64-bit Windows? Dylan FLUENT 4 October 17, 2007 11:14
UDF of Zimont model in fluent Z Main CFD Forum 0 February 17, 2005 03:07
