Command not working in 6.3 which worked in 6.2
Old   February 9, 2007, 23:45
Default Command not working in 6.3 which worked in 6.2
Anindya
Hi everybody,
I used the /solve/dual-time-iterate command in the journal file for fluent 6.2 for running an unsteady case. But when I try to run the same problem using fluent 6.3, it is now giving an error as follows:
Error: eval: unbound variable Error Object: /solve/dual-time-iterate
Could someone please let me know what the problem might be and how to correct it?
Thanks for your help.
Anindya
Old   February 12, 2007, 23:59
Default Re: Command not working in 6.3 which worked in 6.2
phinix
You can try to change as this: solve dual-time-iterate
It works well in fluent6.3 in my files.
By the way, do you know how to format the data file when using monitor/surface to save data?
Thanks
Validation 12.1 vs 6.3, Difference in Reported Inlet Total Pressure jola FLUENT 1 May 5, 2011 14:33
Where to find the difference between fluent 6.3 and version 6.2? legendyxg FLUENT 1 May 7, 2009 03:12
Fluent 6.2 and 6.3 compatibility Ale FLUENT 0 July 31, 2008 03:47
Difference between Version 6.3 and Version 6.2 erikaj FLUENT 0 October 11, 2007 12:36
Backwards compatibility of Fluent 6.3 with 6.2 Brian FLUENT 1 April 4, 2007 21:52
