Iteration Error, Help need!!!
Old   February 15, 2007, 00:23
Default Iteration Error, Help need!!!
phinix
Hello, all
When I run fluent using iterate the following error message displayed. Can anyone help me to figure what is the possible error of my setting?
Thanks Happy new year ===================================== Updating solution at time levels N and N-1. done. iter time/iter
Error: FLUENT received fatal signal (ACCESS_VIOLATION) 1. Note exact events leading to error. 2. Save case/data under new name. 3. Exit program and restart to continue. 4. Report error to your distributor. Error Object: ()
Old   February 15, 2007, 06:52
Default Re: Iteration Error, Help need!!!
amel
hi, I had the same problem in my program, I think because I opened several files in the same window and just after, I start the itérations with discarding other files. so when I closed fluent and opened it again it has calculeted normally. good luck !
Old   February 15, 2007, 15:22
Rizwan
one more reason may be that, the exact events that u followed in setting up a problem is un-realistic. for example providing u have two volumes one below the other. the lower one is a solid interior and top one is a fluid interior. to set a BC for fluid interior volume to one of face is general practice but if u try to giv veolcity inlet to one of the faces of solid interior, u may recieve this type of error. cheks if there r such inconsistencies in setting the case file.
regards
how to increase "Newton Pressure Iteration Limit" kus CFX 9 April 21, 2013 01:54
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 03:23
Parallel runs slower with MTU=9000 than MTU=1500 Javier Larrondo FLUENT 0 October 28, 2007 22:30
Creating, loop or iteration using expression edito Jan CFX 3 July 28, 2003 11:01
Heat exchanger problem chiseung FLUENT 16 October 20, 2001 04:36
