how to display the stream line
Old   February 14, 2007, 12:47
Default how to display the stream line
ice
hallo, everyone,
I have a problem with displaying the stream line in 2D.
I know, I can use the "stream function" in "Contours" to display the stream line. But the maximum of the level is 100. But this refers to the whole region
Is there anyone know, how can I disply it in a certain region more exactly, i.e. near the wall?
Old   February 21, 2007, 08:54
Default Re: how to display the stream line
Khairy
Hi from contour panel uncheck auto rang check clip to range write down the max and min value of stream functiom say if its range 0-->10 you select say 0-->1
i hope these useful Khairy-Egypt
[Gmsh] Problem with Gmsh nishant_hull OpenFOAM Meshing & Mesh Conversion 23 August 5, 2015 02:09
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 flakid OpenFOAM Installation 16 December 28, 2010 08:48
Regarding FoamX running Kindly help out hariya03 OpenFOAM Pre-Processing 0 April 18, 2008 04:26
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
