energy equation solution
Old   February 15, 2007, 03:09
Default energy equation solution
yasmeen
hi i have a converged solution of heat transfer through different fluid and solid.but in have not correctly solved energy equations in the solutions.can anybody help me
Old   February 15, 2007, 05:13
Default Re: energy equation solution
nicoslaw
Please try to change:
Define->models->solver->gradient option to Green-Gauss node based Or Least Squares cell based
Do you solve system with or without chemical reaction? Which version of Fluent do you use?
best regards Nicoslaw
Old   February 20, 2007, 05:01
yasmeen
yes i have already node based and i am not using chemical reaction and my fluent is 6.2 . i have another question for complete solution of energy equations i solved energy and flow equations sepraetly alongwith turbulence. can you tell me that whether it is preferable to solve flow equation first than energy equation
Convergence problem of the energy equation Woo Meng Wai FLUENT 2 May 13, 2008 03:06
Coupling between momentum and energy equation Mattia FLUENT 0 October 26, 2007 08:02
SIMPLE and energy equation convergence Fabio Main CFD Forum 0 June 1, 2007 06:06
How to discretize of energy equation ?? Asghari FLUENT 0 October 12, 2006 08:06
Energy equation convergence problem Reza Main CFD Forum 0 August 27, 2003 13:09
