February 15, 2007, 12:29 |
two fluids two temperature
hi!
Can you help me withthis. Fluent 6.2.16; VOF model. solver segregated, heat and mass transfer udf`s, two zones not seperated from each other (something like a container with water - top is open, bottom is heated). How to set up a diferent temperature for water and diferent temperature for air? (I`m using adopting metod to set up a water in bottom part of container and air in upper part). Please answer me )) |
February 15, 2007, 16:17 |
Re: two fluids two temperature
Once u have adapted the region and patched the water in bottom, u can patch temperature also from the same panel. patching temp to individual phases is no different to patching volume.
Regards Hope this helps |
February 17, 2007, 03:56 |
thank you very much Rizwan.
Display Modes | |
Problem with zeroGradient wall BC for temperature - Total temperature loss | cboss | OpenFOAM | 12 | October 1, 2018 07:36 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Bulk temperature Tf is obtained from total or static temperature? | NPU_conanxie | FLUENT | 0 | March 30, 2011 06:56 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 18:31 |
Heat Exchanger Fluids Lack Temperature Difference | justinF | FLUENT | 2 | July 11, 2007 23:55 |
