How to open Icem mesh in Ansys Fluent?
Like Tree6Likes
Old   September 29, 2009, 12:22
Default How to open Icem mesh in Ansys Fluent?
Emma
emmkell is on a distinguished road
Hi
I am new to Ansys Fluent and Icem, having previously used Gambit and Fluent. I need some help regarding the Solver and Output process from Icem...in order to output a mesh file which can be opened in Ansys Fluent 12.0.
With Gambit and Fluent, it was always very simple - to set the solver in Gambit to Fluent 5/6, and to save the mesh as a .msh file, and just read the mesh file in Fluent.
Icem is saving my mesh file as an unstructured mesh file .uns but I can't seem to open this in Ansys Fluent.
Does anyone have any help on this, or a tutorial guide or something, that would enable me to open my Icem mesh file in Ansys Fluent?!
I apologise as I know this is probably a very basic question, but would really appreciate any help you could give
emmkell is offline   Reply With Quote
Old   September 29, 2009, 13:37
Ryne Whitehill
rwryne is on a distinguished road
I do not use Fluent, but the process should be the same as my solver:
1) in the output tab, click the red tool box and select Fluent as the solver
2) Select the BC Button to the right of the tool box
a) Expand the relevant tabs (usually mixed/unknown and surfaces mixed/unknown)
b) For each boundary you plan on applying a condition: expand it, click Create new, and apply the appropriate condition
3) Once all boundaries are set, click the rubiks cube looking button and export the file
Someone with more Fluent experience might want to add to/correct what I have said, but this should get you going
athonyburk likes this.
rwryne is offline   Reply With Quote
Old   September 30, 2009, 17:11
Post
teguhtf's Avatar
teguh hady
teguhtf is on a distinguished road
Originally Posted by emmkell View Post
Hi
Hi!!
I don't think that it mesh can work. i think ICEM is workin only on edge or vertex. it doesnt work on mesh. Just Like CAD soft ware.
Hope it helps
teguhtf is offline   Reply With Quote
Old   October 3, 2009, 08:44
Emma
Thank you rwryne i got it working :-)
Old   December 17, 2009, 14:31
Carlos
geran is on a distinguished road
I have tried this, but although i created a msh file when i tried to open it with fluent i get an error.
fluent tries to read mesh file and give me (varies with the mesh, i have tried with the 2Dpipe and 2Dcar meshes from ICEM tutorial)
xxxx nodes
yyyy quadrilateral cells, zone 10
zzzz 2D interior faces, zone 11
377 2D walls, zone 12
Building ...
mesh
Error:
FLUENT received fatal signal (ACESS VIOLATION)
What I am doing wrong?
Thx for answer.
granzer likes this.
geran is offline   Reply With Quote
Old   December 18, 2009, 10:23
Emma
I'm not too sure, the only time I've seen that error is when I accidentally tried to open a 2D mesh in the 3D mode. Sorry I can't be of more help.
Old   March 25, 2010, 09:41
ahasan1 is on a distinguished road
I think this is the proper link where I can post the same problem(meshing) that I am facing by ICEM CFD. I am trying to transfer my .msh file (that was made by ICEM CFD) to FLUENT. I am following this command in FLUENT: FILE>READ>MESH
and read the .msh file in FLUENT. After reading the file in FLUENT, I have found that I cannot find boundary conditions in FLUENT that I have assigned in ICEM CFD during transferring file to FLUENT. I have followed this way to find the boundary conditions in FLUENT: DEFINE> BOUNDARY CONDITIONS. Would you please let me know, how I can see boundary conditions in FLUENT that I have assigned in ICEM CFD.
DungPham likes this.
ahasan1 is offline   Reply With Quote
Old   March 25, 2010, 10:08
Emma
This has happened to me before. I figured out the reason it happened was because i created a new part in ICEM AFTER i meshed the geometry. This still allows you to set the Boundary Conditions in ICEM, but they will not transfer over because they are not actually par tof the mesh. You should run the mesh as the last stop before the output.
Hope this helps
DungPham and mustafa aksu like this.
Old   April 7, 2010, 17:59
Default xy plot in FLUENT
I am trying to save my plot/graph in FLUENT after covereged the solution. I am following this command:
Solution XY plot> Options> Write to File > Write....> Enter vel.xy as the XY File Name and click OK
I am getting the below error and the folder created a file name vel, however there is no points information. Please let me know how I can save xy plot.
Error: %cx-raise-window: wta[1] (integer)
Error Object: #f
Old   August 24, 2010, 16:35
Default All boundary types are "wall"
miyashin is on a distinguished road
I am using ICEM CFD 12.1 to generate a mesh, and am trying to load a mesh file (*.msh created with ICEM) on FLUENT 12.1. In FLUENT/Problem Setup/Boundary Conditions, I can see all the zones where I specified boundary condition on ICEM, but "Type" is "wall" for all the zones. I know I can modify the boundary condition on FLUENT, but I was wondering if this is this always the case.
On ICEM, I didn't know how to specify "Zone id" when specifying boundary conditions, so I just gave random numbers. I thought this might be the reason why all the boundary types are "wall". Could anyone tell me how to specify "Zone id" in ICEM/Output/Family boundary conditions/ when Output Solver is Fluent_V6?
***** Added 2hr later *****
For some reason, I was able to export the boundary condition from ICEM correctly when I tried several more times... I don't really know what was wrong. Anyway, it worked well when I left "Zone id" as "0" which is the default.
miyashin is offline   Reply With Quote
Old   June 13, 2011, 11:14
Casey
meangreen is on a distinguished road
Error Object: #f
Did you solve this problem? I am getting the same one.
meangreen is offline   Reply With Quote
Old   February 21, 2012, 06:26
Default .msh file to .iges file
  #12
R. Roy
rr123 is on a distinguished road
I have a big problem. I cant convert from .msh file of a 3D geometry to .iges file format.
Could someone tell me how to get this done ?
Everytime I am trying exporting through the GAMBIT way, it is crashing.
Is there a workaround or other alternate path ?
Best regard,
R.Roy
rr123 is offline   Reply With Quote
Old   February 26, 2012, 23:44
william
faee0 is on a distinguished road
for 2d geometry,you must be sure every curve has been associate to edges.
faee0 is offline   Reply With Quote
Old   June 25, 2012, 11:59
CFD-1987
CFD-1987 is on a distinguished road
I am having the same problem miyashin and although i tried everything i can't find what's wrong.....have you found what's happening????
CFD-1987 is offline   Reply With Quote
Old   August 20, 2013, 03:21
Default ansys fluent
  #15
mariana
MARIANA LOQUITA is on a distinguished road
dear people,
i have huge problem and i do not know how to solve it. i am trying to make mesh for my geometry but i cannot do it. i am doing somewhere mistake and i can understand where. is here anybody who can help me? can somebody show me the process maybe?
did i say please, please and again please?????
MARIANA LOQUITA is offline   Reply With Quote
Old   October 14, 2014, 05:31
Default Hi every one
  #16
Radwanma
Radwanma is on a distinguished road
I want to know how can I make aerofoil in 2D OR 3D in Ansys 13-14-15 ?
Thanks
Radwanma is offline   Reply With Quote
Old   October 14, 2014, 05:38
pakk will become famous soon enough
The question you ask now is too vague to be answered.
What do you mean "make aerofoil"? Design one? Analyze one? Import geometry? Create geometry? Make mesh? Optimize one? Unless you have a 3D-printer or something similar, you can not literally "make" one.
pakk is offline   Reply With Quote
Old   October 14, 2014, 05:49
Default hi
  #18
Radwanma
Thanks , I want to creat aerofoil in ANSYS FLUENT, PLEASE .
Old   October 14, 2014, 06:09
That does not help at all.
I don't know where you start. (do you have geometry? do you have mesh? do you have other things?)
I don't know where you want to go to. (do you want to analyze your design? improve your design? start a design?)
If you can not make your question more clear, I'll have to assume that you don't know what you want, and then I can not help you.
Old   October 14, 2014, 07:21
Radwanma
How can I darw an aerofoil by using ansys ? is it ok are understand what I mean ?
Problem with 2D ICEM mesh check in fluent Nicola FLUENT 3 March 25, 2013 05:56
ICEM BC to FLUENT Simon CFX 3 September 9, 2008 17:08
OpenFOAM with IBM AIX matthias OpenFOAM Installation 20 March 25, 2008 02:36
How to control Minximum mesh space? hung FLUENT 7 April 18, 2005 09:38
Exporting ICEM Mesh into Fluent... Harmeet FLUENT 1 July 28, 2004 02:56
