Laminar Flow and Particle Track: Inconsistent?
Old   February 20, 2007, 14:47
Default Laminar Flow and Particle Track: Inconsistent?
Domenico
Hi guys,
I am running a very simple laminar case in a straight annular pipe, and I did generate a solution using velocity inlet boundary condition and a pressure outlet b.c.
I double checked the velocity profile which match very well the analytical solution available in textbooks, but, surprisingly, when I tried to inject particles at the inlet...well...such particles don't quite follow the velocity streamline. It seems they cluster annular regions of the reactor. And I don't have particle closed to the external wall.
FYI, I defined particle with the same density of the water and I did not include any gravity effect. So, I can't undestand particles shouldn't follow streamlines...
Any thoughts?
how can I get the unsteady flow pathline,to use particle track? pp8997 FLUENT 0 January 23, 2010 22:11
may i import flow field data to do particle track? Hao FLUENT 8 April 29, 2008 08:22
Laminar Flow and Particle Track: Inconsistent? Domenico FLUENT 0 February 20, 2007 14:49
Tutorial PARTICLE SETTLING IN LAMINAR FLOW moh FLUENT 0 July 14, 2004 04:09
liquid particle track and flow rate Tim FLUENT 1 November 28, 2001 21:41
