How to set the wind tunnel Boundary conditions in Fluent??? |
April 13, 2009, 14:12 |
Saima
Rep Power: 16 |
Hi ,
I have a problem in which a heater is on leading edge of an airfoil, placed in wind tunnel. Air is inside the tunnel at -5C. And water spray by using atomizer is also there. This airfoil is placed inside the wind tunnel.I want to setup the boundary conditions. I took, 1. Velocity inlet (bcoz i know the initial velocity which is constant in entire process) 2. Outflow 3. The bottom and top wall (wall with zero shear) I want to know what could be the boundary conditions for top and bottom walls of Wind tunnel? It is very urgent. Many Many thanks in advance. Regards, Saima |
April 14, 2009, 00:12 |
Raheel Rasool
Rep Power: 17 |
You can take them as wall and specify zero as shear value to avoid boundary layer generation there and cross flow across the wall.
Just an idea!!! Regards, Raheel |
Fluent - boundary conditions | Vijay | FLUENT | 3 | January 9, 2009 11:42 |
Sloshing Boundary Conditions in Fluent | Prabodh | FLUENT | 0 | April 16, 2006 05:52 |
Gambit boundary conditions not suitable for fluent | ann | FLUENT | 3 | October 12, 2005 12:51 |
UDF to set boundary conditions | philip | FLUENT | 2 | June 17, 2005 09:11 |
Please help with flow around car modelling! | Tudor Miron | CFX | 17 | March 19, 2004 19:23 |
