Meshing Volume Error
Old   March 10, 2007, 02:54
Default Meshing Volume Error
Hassan
Hello Firends
I would like to say that while meshing the volume , there were an error that appears in the transcript windows saying :ERROR : Face Face.15 has less than three boundary nodes on one or ore of face node loops , which prevents it from being meshed . this Error appear for 5 faces : 1, 15 ,22 ,23 ,59 ;(this faces are on the base of the wind turbine )
so What shall i do ?? I need to mesh the volume but i couldnt bcoz of this ; I will appreciate ur help thanks
Old   March 12, 2007, 11:10
Default Re: Meshing Volume Error
Seeker Phil
You will need to look at those faces again. In order to mesh a face, you need at least 3 edges or 3 boundary nodes. Zoom into the faces with the error and see if you can find why Gambit sees it as less than 3 faces. - Phil
Old   March 12, 2007, 11:34
Hassan
thank you very much foryou reply , i will try to look into these faces Hassan
polynomial thermophysical properties II sebastian OpenFOAM Running, Solving & CFD 54 November 21, 2019 07:12
[OpenFOAM] Native ParaView Reader Bugs tj22 ParaView 270 January 4, 2016 11:39
POSDAT problem piotka STAR-CD 4 June 12, 2009 08:43
user subroutine error CFDUSER CFX 2 December 9, 2006 06:31
user defined function cfduser CFX 0 April 29, 2006 10:58
