how to set initial pressure in a closed system
Old   March 12, 2007, 06:43
Default how to set initial pressure in a closed system
ypbanjare
hi
I am modelling a refrigeration system consisting of compressor , aftercooler, regenerator ,cold and hot end heat exchanger connecting tube and reservoir. This is a complete closed system.I want to set initial charging pressure of the whole system at 50 bar.Means when time t=0 whole system is at 50 bar.When reciprocating compressor piston moves back and throgg the compression and expanssion of gas takes place. Please help how to set this initial pressure.
Y.P. Banjare
Old   March 12, 2007, 11:34
Default Re: how to set initial pressure in a closed system
Seeker Phil
Did you try initializing your flow field? Solve->Initialize-> Initialize -Phil
Floating point exception error Alan OpenFOAM Running, Solving & CFD 11 July 1, 2021 21:51
Moving mesh Niklas Wikstrom (Wikstrom) OpenFOAM Running, Solving & CFD 122 June 15, 2014 06:20
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 bookie56 OpenFOAM Installation 8 August 13, 2011 04:03
Negative value of k causing simulation to stop velan OpenFOAM Running, Solving & CFD 1 October 17, 2008 05:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
