Close-domain model of time-dependent compres. flow
Old   March 19, 2007, 11:35
Default Close-domain model of time-dependent compres. flow
Spiro
Hello
Has anyone in here ever attempted to model a detonation in a non-vented structure? i.e. a ship's hold.
I am interested in knowing the appropriate settings of such a model:
My solver is Pressure-Based & Gradient Option is Green-Gauss Node Based
Viscous Model: Sparlat-Allmaras (1 Eqn.)
Energy Eqn. is ON
Materials: Air (ideal gas)
Solution Ctrls: Pressure-Velocity Coupling (PISO???)
Discretization
Pressure - 2nd order
Density - 2nd order
Momentum - 2nd order
Modified Turb. Viscosity - 2nd order
Although I am setting everything on 2nd order when I check the case I get the following message: Consider using higher order discretization for improved accuracy of the final solution.
Do you guys have any ideas on the above? I am not very strong on CFD as I am more into the structural side of the story. I need to use CFD in order to read the pressures acting on the structure's walls after the detonation.
Any opinion/suggestion is highly appreciated.
Thank you
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 11:08
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 07:25
Modeling in micron scale using icoFoam m9819348 OpenFOAM Running, Solving & CFD 7 October 27, 2007 00:36
Unsteady flow in discrete time domain TW Seo FLUENT 0 November 26, 2002 12:30
