March 21, 2007, 12:07 |
color contours with black line edges
I need your help in plotting the contours with black edge lines in FLUENT. Contours seperated by black edge lines. Your quick help is very much needed for my report preparation. Please add some tips in grabbing good quality pictures direclty from FLUENT I have increased the text size from default value. I'm expecting the quality of the pictures to further improve with above procedure. Thanks in advance Anish, IIT Madras |
March 21, 2007, 12:08 |
Re: color contours with black line edges *NM*
March 28, 2007, 01:02 |
Try to draw filled contours, after that switch Display/Scene/Overlays and now use only lines instead of filled contours. The appropriate min and max values are necessarry.
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
OpenFOAM 1.7.1 installation problem on OpenSUSE 11.3 | flakid | OpenFOAM Installation | 16 | December 28, 2010 08:48 |
Regarding FoamX running Kindly help out | hariya03 | OpenFOAM Pre-Processing | 0 | April 18, 2008 04:26 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
error while compiling the USER Sub routine | CFD user | CFX | 3 | November 25, 2002 15:16 |
