Negative volumes
Old   March 20, 2007, 22:38
Default Negative volumes
Christie
As part of my Aircraft Design Project I am doing CFD on an NLF airfoil with varying AoAs and Aileron/Flap settings. The airfoil with 0 aileron and flap deflection works fine - meshed and ran in fluent without errors. My problem is with the airfoils with aileron and flap deflections.
I meshed the airfoil with a -2 deg deflection of the aileron the similar to how I did the airfoil with no deflection, however when checking the grid in fluent with the meshed airfoil with aileron deflection I get a Failed grid check error due to negative volumes.
Are there any suggestions as to how I may remedy this? What I have tried thus far is changing the mesh size/type with no luck.
Thanks in advance!
Old   March 29, 2007, 02:49
Default Re: Negative volumes
Rohan
Check the skewness of the face meshes.
Try to bring them down below .7
Should work fine.
Thanks
Regards
Rohan
Old   March 29, 2007, 08:46
Christie
Thanks for the response. I've actually figured it out a while a go and have moved on from the airfoil to the fuselage.
Thanks again though
channelFoam for a 3D pipe AlmostSurelyRob OpenFOAM 3 June 24, 2011 13:06
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
negative grid volumes when adapting Dave FLUENT 1 August 20, 2005 13:47
Problem in identifying Negative volumes in Fluent Senthil FLUENT 1 April 19, 2003 10:16
