April 4, 2007, 10:02 |
viscosity
Hello, what model do you use for viscosity of species as a function of temperature in the range 500K-2000K ? Is the Sutherland's law appropriate? If not, what do you suggest? Do you know any correlation in that range or any table with viscosity of species at different temp/press that can be eventually used to fit a polynomial? Thanks in advance.
Eulerian Modeling: Frictional Viscosity Help | meangreen | FLUENT | 1 | January 25, 2018 15:13 |
Power - Law Viscosity Model for Polymers | NickolasPl | OpenFOAM | 2 | August 12, 2011 08:26 |
Turbulence viscosity limited | Madhukar Rapaka | FLUENT | 0 | June 26, 2006 03:17 |
kinematic viscosity at diff temperatures,pressures | Mecobio | Main CFD Forum | 0 | November 7, 2005 12:55 |
Problem of Turbulent Viscosity Ratio Limited | David Yang | FLUENT | 3 | June 3, 2002 06:13 |
