Question to UDF
Old   April 10, 2007, 11:20
Default Question to UDF
Claud
Hi users, I am modelling a 2D gas flow over a catalytic layer where steam reforming takes place. For getting the reactions in the catalyst I have written an UDF (3 global reactions with some kinetic parameters). The problem that I am facing is that sometimes I do not have any problems when I turned on the reaction and sometimes I run into the following error: Floating point error: invalid number. Any suggestion how to overcome that problem? Before I hooked on the UDF I have done some iterations until I got a stable flow in the reactor and I have lowered the URF for each species to 0.5.
Thanx for your help! Claud
Old   April 10, 2007, 17:02
Default Re: Question to UDF
Phil
try a different number type for your variables.(ie. int,real,float,double)
A simple UDF question Pirooz Darabi FLUENT 0 October 31, 2007 15:22
Basic question: UDF for wall heat flux Carl FLUENT 1 August 5, 2006 19:01
Question about UDF summer FLUENT 1 July 18, 2006 10:13
UDF question Ryan FLUENT 2 July 5, 2006 14:54
A question about the dynamic mesh UDF Tango FLUENT 1 November 27, 2003 02:56
