memory
have you ever had this error? the mesh I have has 1346108 nodes. The memory on the computer is 4GB RAM. Any advice? Thanks Warning: ST_Malloc: out of memory.malloc_storage: unable to malloc Body Force Corr |
Re: memory
Hi, is it required any configuration to make FLUENT using all the available memory? thanks
Re: memory
Hi, first of define your OS, number of cpu's, solver settings . This error might happen if you are running Fluent under 32-bit XP with coupled solver. In this case memory limit per cpu is 2gb and it is not enough for coupled solver and your mesh.
Re: memory
Thanks Albert, actually I'm using Fluent under 32bit XP with a dual core. what do you mean in defining the OS and how to define the # of CPU?
