Blades inside a cylinder
Old   April 21, 2007, 05:07
Default Blades inside a cylinder
Oleg
Hello , I have a 4 blades inside a cylinder , and i wan t to mesh this volume & export it into fluent . I first substracted the two volumes , then i meshed the computational domain with tet intervals 3 .i assigned as BC inlet , outlet , Wall (velocity, pressure outlet). I wan tto solve it using MRF .
My Questions :1- is that right what i have done until now ?
2- I will assign the wall as a Moving frame in Fluent ?
Plz reply ASAP , and advices and hints are welcomed ;
Oleg
Old   April 23, 2007, 10:52
Default Re: Blades inside a cylinder
Hussein
I think u r right
simulation of piston motion inside a hydraulic cylinder mosman Main CFD Forum 0 August 7, 2011 01:40
simulation of piston motion inside a hydraulic cylinder mosman FLUENT 0 August 6, 2011 15:44
[snappyHexMesh] SnappyHexMesh Meshing inside a cylinder nammari OpenFOAM Meshing & Mesh Conversion 5 March 11, 2011 19:49
[blockMesh] Meshing inside a cylinder so that the edges contain more cells than the center Bertrand OpenFOAM Meshing & Mesh Conversion 1 April 13, 2010 04:46
meshing F1 front wing Steve FLUENT 0 April 17, 2003 12:37
