April 26, 2007, 04:33 |
Reverse Flow problem
I am simulating the flow in a stirred bead mill. For the continuous case, I am getting reverse flow for low flow rates. Can this be corrected?
April 26, 2007, 13:55 |
Re: Reverse Flow problem
I believe this is dependent on the turbulance parameters that you setup to calculate turbulance at your aboundary conditions. What turbulence approximation are you using?
April 27, 2007, 05:31 |
check whether you have specified the backflow parameters sufficiently, and also the reference conditions.too much of turbulance at low pressure ratios causes rapid reverse flow.
Display Modes | |
Back Flow problem | siddharameshwara | OpenFOAM Running, Solving & CFD | 7 | February 23, 2017 11:02 |
Flow simulation in reverse drum mixer | Patel Chirag | CFX | 0 | July 19, 2010 16:05 |
Reverse Flow at Rotating Pipe Outlet | vismech | STAR-CCM+ | 1 | August 11, 2009 11:38 |
Can 'shock waves' occur in viscous fluid flows? | diaw | Main CFD Forum | 104 | February 16, 2006 06:44 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 13:19 |
