April 30, 2007, 14:26 |
reversing faces
Hi, I'm using the fluent parallel solver on a dual core computer. Importing a 3D mesh I have the following warning message: "Warning: Reversing 30876 faces, zone 4." If I read the same mesh in the serial solver there is no such a warning, but I cannot run the simulation because of memory requirements. What that message means and how to fix it? thanks
April 30, 2007, 14:36 |
Re: reversing faces
try reading the mesh and write the case in "serial" and read the "case" not mesh in parallel.
February 24, 2012, 02:40 |
Hossein
that was wonderful bashu!!! but i have a question: what problem occure if there is such a warning? I am simulating a 2D reactor impeller and have such a warning in my simulation.
April 9, 2016, 15:56 |
Kadu
Rep Power: 10 |
It could be because of mesh not been done somewhere... In my case, it was giving same problem - 'reversing faces ....' while reading mesh. But later I found mesh hadn't been done. When I did meshing again, it worked in parallel also.
July 13, 2018, 16:33 |
Nidhi
Rep Power: 8 |
I don't understand what you mean by "mesh had not been done". Can you please explain? Do you mean that the mesh was not read properly? or that it was not exported into fluent format?
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! | sc298 | OpenFOAM Meshing & Mesh Conversion | 2 | March 27, 2011 21:11 |
DecomposePar unequal number of shared faces | maka | OpenFOAM Pre-Processing | 6 | August 12, 2010 09:01 |
[snappyHexMesh] external flow with snappyHexMesh | chelvistero | OpenFOAM Meshing & Mesh Conversion | 11 | January 15, 2010 19:43 |
Problem in IMPORT of ICEM input file in FLUENT | csvirume | FLUENT | 2 | September 9, 2009 01:08 |
Unaligned accesses on IA64 | andre | OpenFOAM | 5 | June 23, 2008 10:37 |
