Dynamic moving reference frame
Like Tree1Likes
  • 1 Post By Peter Wilkins
Old   May 1, 2007, 08:23
Default Dynamic moving reference frame
Peter Wilkins
Hi all,
I'm modelling a rotating wing using a moving reference frame. I can do this easily for a constant speed rotation, but is there a way of using the same technique for an accelerating wing? I can't see a way to use a UDF to define the rotational speed of my MRF.
Thanks,
Peter
mina likes this.
Old   May 1, 2007, 09:11
Default Re: Dynamic moving reference frame
Hussein
Hello , I am also modeling a rotating wing using a moving reference frame , f u want we can be in contact in case some of us need help ? if yes , let me know
Old   May 1, 2007, 09:15
Peter Wilkins
Sure. I am able to model a wing rotating at constant angular velocity but I want to model a wing which is rotating at an increasing rate. Any ideas?
Peter
Old   May 1, 2007, 09:37
Hussein
I trhink in the User defined functions UDF is the best way , frankly i am not so good in UDF , However the main idea behind the function should be , increasing at a constant rate or increasing arbitrarily , personaaly i prefer workin on c . I did my work on a constant speed rotation as a first step , but i didn it on a "Bad Wing" . now i have to do it again with a NACA 0015 . is that good ? also , i had an idea about drawing the Wing as a 3d dimensions , i thought that the best method to draw it is to , import the vertex of a 2d airfoil , then tryin to convert this 2d into 3d through the addition of many 2 airfoils then joinnig them .
I am not sure about drawing a naca 0015 as a 3dimensin since i worked on a arbitrarily 3 dimension wing .
any idea of drawing ?
Old   May 2, 2007, 07:10
Phil
But are you using the unsteady solver as you will need to with an accelerating component? Sliding meshes are the best way.
- Unsure whether you need a UDF to do this, but you could simply SET THE ROTATIONAL SPEED TO INCREASE WITH EACH TIME STEP. I have no real experience in this specific case but I would have thought this was the only way to do it.
Old   May 3, 2007, 04:39
Peter Wilkins
Phil,
Yes I am using an unsteady solver. I could manually increase the rotational speed with each time step but I wanted to write a UDF so that I could do it more efficiently.
Peter
Old   May 3, 2007, 06:12
Phil
how is your experience with UDF's?
there should be a define macro to change boundary conditions at the end of each time step. Use the examples as a reference. If you already know this then sorry I can't help you further unless you're doing combustion.
Second Derivative Zero - Boundary Condition fu-ki-pa OpenFOAM 11 March 27, 2021 04:28
Constant velocity of the material Sas CFX 15 July 13, 2010 08:56
Error with Wmake skabilan OpenFOAM Installation 3 July 28, 2009 00:35
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 00:34
