-   FLUENT (https://www.cfd-online.com/Forums/fluent/)
-   -   Gambit + Exceed - "cannot open stream" (https://www.cfd-online.com/Forums/fluent/44589-gambit-exceed-cannot-open-stream.html)
PaulD May 3, 2007 08:42
When i start Gamibit, i get the following message:
Cannot open connect stream.
TRANS(SocketINETGetAddr): tnamebysocket() failed
TRANS(SocketINETConnect): TRANS(SocketINETGetAddr) () failed
TRANS(Open): transport open failed for tcp/XPS1710.network.LAN:0 Unable to open display
Can anyone help ?
Phil May 3, 2007 09:04
Re: Gambit + Exceed - "cannot open stream"
have you installed exceed properly?
PaulD May 4, 2007 02:33
I think so - the Exceed splash-screen pops up when I try to launch Gambit - i don't however get any form of X-window (which i might have expected) - are there some particular settings within exceed I should use ?
Phil May 4, 2007 08:57
is the 'hummingbird neighborhood' icon on your desktop?
Also I had a problem a while back when my firewall blocked internet access from Gambit. You don't even need the cable plugged in as long as Gambit thinks it has access to the Web.
ACHILLEAS TSOMPANOS May 4, 2007 09:58
Same problem here. Exceed installed, opens window but not X-window. The application fails to start gambit. What about this firewall. Should i disable it?
Regards Achilleas Tsompanos
PaulD May 5, 2007 04:05
Phil - it was the firewall ! As you indicate, even with cable plugged out, it still wouldn't run until i disabled my McAfee personal firewall.
Thanks for your help - i would never have sussed it otherwise.
Paul
Phil May 5, 2007 11:44
Go into your firewall and manually allow access to Gambit. You probably disabled access when prompted by accident.
Tsompanos May 8, 2007 10:14
but i have disabled the firewall option of windows xp!
Phil May 8, 2007 10:39
it's not usually the windows firewall that causes a problem but one that may have came with your pc, like zonealarm/norton/mcafee,etc. You should either go into the main firewall and enable internet access for Gambit or shut the firewall down. Make sure it's also away on the list of icons at the bottom right hand corner of your screen.
If you don't have a firewall(you should get one!) then post the full error message on the forum.
ACHILLEAS TSOMPANOS May 9, 2007 09:38
It gives me a warning for using exceed 6.1 and then says "unable to open window"
RIZWAN_CHEMICAL June 10, 2011 06:53
CAN ANY ONE HELP WITH THIS
Locating Exceed installation .
gambit failed in locating Exceed installation on your system.
